查看: 268|回复: 0
OMAP-L138 DSP开发套件
发表于 2016-4-25 09:11:49 | 显示全部楼层 |阅读模式
PROFIBUS 套件提供所有的硬件和软件支持给系统设计人员和开发人员在评估PROFIBUS的AM1810或OMAP L138微处理器以及的关键环节MityARM-1810或MityDSP-L138系列系统模块遇到的问题。In addition, the PROFIBUS DEVELOPMENT KIT includes on board RS-232, 10/100 MBit Ethernet, Universal Serial Bus (USB) Host and USB-On The-Go (OTG) communication interfaces and an Electrically Isolated CAN interface. The single UART expansion port allows for the connection of either the PROFIBUS/RS-485 expansion board (included with the PROFIBUS Development Kit) with 2500V galvanic isolation barrier or a simple RS232 serial port expansion kit (optional). Integrated Digital Video Interface (DVI) controller for external display connection with DDC support. Interface to QVGA\WQVGA display via 5 pair LVDS link with additional SPI interface for resistive touch controller (requires an FPGA based module to be installed), Multi Media Card (MMC) interface, 3 I/O Expansion connectors for custom add-on card and integrated power supply with +3V/+5V/±12V outputs from single 12VDC input.FEATURES
  •  PROFIBUS Interface
    •  Certified by PI International
    • Real-Time Linux Drivers
    •  Electrically Isolated Interface
    •  Up to 6Mbaud operation
  • PROFIBUS Support using
    •  MityARM-1810 and 1810F
    •  MityDSP-L138 and L138F 
  •  RS485 Support Only using
    •  MityARM-1808 and 1808F
  • Software Included: 
    •  Real-Time Linux Kernel 
    •  uBoot 
    •  User Boot Loader 
    •  PROFIBUS PRU Image (binary) 
    •  Slave PROFIBUS Stack (evaluation version)
PROFIBUS Dev Kit User's Guide.pdf
670.64 KB, 下载次数: 0
GMT+8, 2025-1-13 08:00 , Processed in 0.114742 second(s), 16 queries , MemCache On.
