查看: 293|回复: 0
LTC3588能量收集器
发表于 2016-4-22 08:35:17 | 显示全部楼层 |阅读模式
LTC3588是压电能量收集电源,集成了低噪音全波整流和高效降压转换器,组成完整的能量收集解决方案,最适合高输出阻抗的能量源如压电传感器.输入电压2.7V-20V,输出电流高达100mA,可选输出电压1.8V, 2.5V, 3.3V和3.6V,可用于压电能量收集,电机械能量收集,无线HVAC传感器,轮胎压里传感器,遥控光开关,毫微瓦降压稳压器。特性
  • 950nA Input Quiescent Current (Output in Regulation–No Load)
  • 450nA Input Quiescent Current in UVLO
  • 2.7V to 20V Input Operating Range
  • Integrated Low-Loss Full-Wave Bridge Rectifier
  • Up to 100mA of Output Current
  • Selectable Output Voltages of 1.8V, 2.5V, 3.3V, 3.6V
  • High Efficiency Integrated Hysteretic Buck DC/DC
  •  Input Protective Shunt–Up to 25mA Pull-Down at VIN ≥ 20V
  •  Wide Input Undervoltage Lockout (UVLO) Range
  •  Available in 10-Lead MSE and 3mm x3mm DFN Packages
GMT+8, 2025-1-13 08:08 , Processed in 0.098956 second(s), 15 queries , MemCache On.
