描述德州仪器的bq34z110是燃油表解决方案,独立工作的电池系列电池配置,并支持铅酸电池化学反应。电池从4 V到64 V可以支持通过一个外部电压转换电路。The bq34z110 device provides several interface options, including an I2C slave, an HDQ slave, one or four direct LEDs, and an Alert output pin. Additionally, the bq34z110 provides support for an external port expander for more than four LEDs.特性Supports Lead-Acid ChemistriesCapacity Estimation Using Patented ImpedanceTrackTM Technology for Batteries from 4 V to 64 VAging CompensationSelf-Discharge CompensationSupports Battery Capacities Above 65 AhrSupports Charge and Discharge Currents Above 32 AExternal NTC Thermistor SupportSupports Two-Wire I2CTM and HDdQ Single-Wire Communication Interfaces with Host SystemSHA-1, HMAC AuthenticationOne- or Four-LED Direct Display ControlFive-LED and Higher Display Through Port ExpanderReduced Power Modes14-Pin TSSOP Package |
