亲,“电路城论坛”已合并升级到更全、更大、更强的「新与非网」。了解「新与非网」
Proximity detection adjustable from under 1 cm up to 200cm Up to three independent LED drivers 30 current settings from 5.6mA to 360mA for each LED driver Operates in direct sunlight with optional on-die 940nm passband filter On die 940 bandpass filter that rejects unwanted visible light and IR from daylight and other sources. (Si1153-AA09)
Broad sensitivity from green to 940 nm (Si1153-AA09) 3 LED drivers ideal for wrist applications
<100mlx resolution possible, allowing operation under dark glass Up to 128klx dynamic range possible across two ADC range settings
1.62 to 3.6V supply voltage 9µA average current (LED pulsed 25.6µs every 800ms at 180mA plus 3µA Si1153 supply) <500nA standby current 25.6µs LED "on" time keeps total power consumption duty cycle low without compromising performance or noise community Internal and external wake support Built-in voltage supply monitor and power-on reset controller
Up to 3.4Mbps data rate Slave mode hardware address decoding
10-lead 2x2x0.65mm QFN 10-lead 2.9x4.9x1.2mm module with integrated 940nm LED
-40 to +85°C
Si1133、 Si1153 Optical Sensor Evaluation Board User's Guide.pdf
2016-5-4 10:59 上传
点击文件名下载附件
1.69 MB, 下载次数: 33
下载资料失效了?点击此处告知管理员 > >
本版积分规则 发表回复 回帖后跳转到最后一页
查看 »
GMT+8, 2024-9-22 10:38 , Processed in 0.136232 second(s), 17 queries , MemCache On.
