查看: 335|回复: 0
ATMEGA328P AVR单片机评估板
发表于 2016-5-5 09:34:14 | 显示全部楼层 |阅读模式
ATMEGA328P 基于爱特梅尔RISC高性能、低功耗的8位AVR单片机结合32KB ISP闪存读写的能力,1024B EEPROM,2KB SRAM,23个通用I / O口线,32个通用工作寄存器,三种灵活的定时器/具有比较模式,内部和外部中断,可编程串行USART,面向字节的2线串行接口,SPI串行计数器端口,一个6通道10位A/ D转换器(TQFP和QFN/ MLF封装的8通道),具有片内振荡器的可编程看门狗定时器,以及五种可以通过软件选择的省电模式。该器件1.8-5.5伏之间运行。Features
  •  High Performance, Low Power Atmel®AVR® 8-Bit Microcontroller Family
  •  Advanced RISC Architecture
    •  131 Powerful Instructions
    •  Most Single Clock Cycle Execution
    •  32 x 8 General Purpose Working Registers
    •  Fully Static Operation
    •  Up to 20 MIPS Throughput at 20MHz
    •  On-chip 2-cycle Multiplier
  •   High Endurance Non-volatile Memory Segments
    •  4/8/16/32KBytes of In-System Self-Programmable Flash program memory
    •  256/512/512/1KBytes EEPROM
    •  512/1K/1K/2KBytes Internal SRAM
    •  Write/Erase Cycles: 10,000 Flash/100,000 EEPROM
    •  Data retention: 20 years at 85C/100 years at 25C(1)
    •  Optional Boot Code Section with Independent Lock Bits In-System Programming by On-chip Boot Program True Read-While-Write Operation
    •  Programming Lock for Software Security
  •  Atmel® QTouch® library support
  •  Capacitive touch buttons, sliders and wheels
  •  QTouch and QMatrix® acquisition
  •  Up to 64 sense channels
Introducting Pro Trinket.pdf
3.22 MB, 下载次数: 1
GMT+8, 2024-11-24 20:39 , Processed in 0.110803 second(s), 16 queries , MemCache On.
