查看: 295|回复: 0
USB高速FPGA开发模块
发表于 2016-5-6 09:25:40 | 显示全部楼层 |阅读模式
FTDI's Morph-IC-II平台结合了一个Altera中带有高性能USB2.0功能的Cyclone®-II FPGA,方便超高速通信,以100毫秒的速度FPGA编程和可重复编程。非常适合需要用户可以通过下载USB软件 和"morphing"硬件来重新配置“即时”硬件功能的应用程序。除了提高应用的灵活性,通过USB重新配置硬件也可以降低BOM成本,因为FPGA其大小只需要为最复杂离散功能而不是所有潜在功能。Feature
  • FT2232HQ Dual, Hi-Speed USB UART/FIFO IC used for USB communications
  • Altera Cyclone 2 - EP2C5F256C8N FPGA capable of synthesizing large scale integrated circuits
  • Ultra-fast FPGA configuration/reconfiguration over USB (under 0.1 sec)
  • 4,608 Embedded FPGA Logic Elements (about 80,000 Gates typically)
  • 26 Embedded Logic RAM Elements (119 Kbits)
  • FPGA-PC USB Data Transfer at up to 40 Mbytes/sec
  • Onboard 93LC56B configuration EEPROM
  • MOSFET switched 5 V and 3.3 V power outputs for powering external logic
  • Onboard 12 MHz crystal and essential support components for FT2232HQ
  • 80 dedicated external I/O pins
  • Onboard 50 MHz oscillator as FPGA primary clock – also available for external use
  • JTAG interface for testing the I/Os and registers of the FPGA
  • One dedicated external clock input
  • Powered from USB bus or external PSU
  • Standard 0.1 inch pitch format connector pins, ideal for rapid prototyping or small-medium size production runs
  • FTDI's VCP and D2XX USB Windows and Linux USB drivers (provided) eliminate the need for driver development in most cases
  • FPGA loader interface DLL (for Windows only not including CE) supplied including interface examples in VB, VC++ and Delphi
  • Stand-alone FPGA loader programs provided for Windows and Linux
  • VHDL programming examples (I/O over USB) provided
  • Delphi application software examples including source code provided
  • Free Altera Quartus II Software Starter Suite development software available from the Altera Website
  • Backward compatible with the existing MorphIC-I
  • Supports 1.5/1.8/2.5/3.3 V LVTTL/LVCMOS signals, IOBANK1-3 restricted to 3.3 V
Morph-IC-II Datasheet.pdf
1.11 MB, 下载次数: 1
GMT+8, 2024-11-24 20:34 , Processed in 0.117217 second(s), 16 queries , MemCache On.
