Grove超声波传感器是一种非接触式距离测量模块,其作频率在42千赫兹,适用于要求中距离测量项目。Seeed Studio Grove Sensors are part of the Grove system of modulated, ready-to-use tools. Seeed Studio Grove sensors consist of a base shield and various modules with standardized connectors. The base shield allows for easy connection of any microprocessor input or output from the Grove modules. Every Grove module addresses a single function, such as a simple button or a more complex heart rate sensor. Each sensor module comes with clear documentation and demo code to help users get started quickly.Grove sensors include a wide range of offerings that fit into the categories of environmental monitoring, motion sensing, user interface, physical monitoring, logic gate, or power.Feature
- Operating voltage: 3.3/5.0VDC
- Operating current: 15mA
- Ultrasonic frequency: 42kHz
- Measuring range: 3-400cm
- Resolution: 1cm
- Output: PWM
- Suli-compatible Library
