查看: 403|回复: 0
ACS712低电流传感器
发表于 2016-5-12 09:11:28 | 显示全部楼层 |阅读模式
电流传感器给出精确的AC和DC电流测量信号。这些是在计量和测量系统中总功耗都很好的传感器。ACS712电流传感器最高测量值为5A的直流或交流电流。我们为了更灵敏的电流测量增加了一个运算放大器增益级。通过调整增益(从4.27到47)可以测量非常小的电流。ACS712低电流传感器突围输出的模拟电压能够感测其电流线性变化。为了校准,首先设置输出偏移到最想要的级别(使其感测线的电流为零,读取具有DVM输出)。Features and Benefits
  •  Low-noise analog signal path
  •  Device bandwidth is set via the new FILTER pin
  •  5 μs output rise time in response to step input current
  •  80 kHz bandwidth
  •  Total output error 1.5% at TA = 25°C
  •  Small footprint, low-profile SOIC8 package
  •  1.2 mΩ internal conductor resistance
  •  2.1 kVRMS minimum isolation voltage from pins 1-4 to pins 5-8
  •  5.0 V, single supply operation
  •  66 to 185 mV/A output sensitivity
  •  Output voltage proportional to AC or DC currents
  •  Factory-trimmed for accuracy
  •  Extremely stable output offset voltage
  •  Nearly zero magnetic hysteresis
  •  Ratiometric output from supply voltage
ACS712-Datasheet.pdf
643.02 KB, 下载次数: 2
GMT+8, 2024-11-24 20:27 , Processed in 0.115896 second(s), 16 queries , MemCache On.
