TA的每日心情 | 开心 2013-9-2 09:06 |
签到天数: 11 天 连续签到: 1 天 [LV.3]偶尔看看II
恩智浦JN516X-EK001评估套件是特别设计用于JN516x系列微控制器的,此微控制器功耗超低、无线功能性能高,适用于JenNet-IP、RF4CE的远程控制和ZigBee应用。This comprehensive kit, which includes a series of wireless carrier boards, plug-in expansion boards, USB dongles, a remote control, a specially programmed Cisco router, and a complete software design kit, provides everything necessary for system development.The supplied router, which runs NXP OpenWRT firmware modified by NXP, makes it easy to develop solutions that include sensor-equipped objects as part of the "Internet of Things."Using the various demos included in the kit, designers can quickly produce demonstrators or proof-of-concept products. The same software can then be used for end products, using JN516X ICs or modules. The Smart Lighting demo, which makes use of nearly all the kit's components, is a JenNet-IP demo that uses the router to support connection to a WLAN or the Internet. The evaluation kit can easily be Flash programmed for use with ZigBee LL, ZigBee SE, or RF4CE demos.The ZigBee SE demo lets the user experiment with an energy service portal (via the USB dongle), an in-premise display (using the display expansion board), standalone meters for electricity and gas, or a range extender. The ZigBee LL demo gives the designer remote control of color LEDs on the lighting expansion board.The RF4CE demo lets the user select, play, forward, stop, pause, or change the volume on a Windows media player.The kit also includes a network sniffer license from Ubilogix, free for use for 45 days, that works with the second USB dongle as the primary device.The JN516x series:JN516x series devices feature an enhanced 32-bit RISC processor with embedded Flash and EEPROM memory, offer high coding efficiency through variable width instructions, a multi-stage instruction pipeline, and low-power operation with programmable clock speeds. They also include a 2.4 GHz IEEE802.15.4-compliant transceiver and a comprehensive mix of analog and digital peripherals.
特性
- 16-button capacitive touch remote control
- One LCD expansion board
- Two USB dongles
- Cisco router with Ethernet support
- Complete software development kit (SDK)
- GNU-based toolchain with C compiler
- Flash programmer
- Eclipse IDE with integrated GNU debugger (GDB)
- Microcontroller and peripheral libraries
- Quick, easy product development
- Free, unrestricted Eclipse-based SDK
- Hardware platform supports all sensors, displays, LEDs, switches
- One evaluation kit for all applications
- Four base boards
- Three lighting expansion boards
- Two expansion boards with sensors and buttons
