查看: 234|回复: 0
LM10010评估板
发表于 2013-2-22 10:10:27 | 显示全部楼层 |阅读模式
该评估模块提供了一个VID接口,用来演示LM10010和对LM21215A -1降压型稳压器的控制。While operating from 3.0V to 5.5V, the LM10010 can adjust the LM21215A-1 output voltage from 0.7V to 1.1V in 6.4mV steps with a default startup output of 1.0V. A communications dongle and cable is provided with software to control the output voltage through a graphical user interface (GUI) and an USB port.
特性
Contents:
  • Assembled LM10010 Evaluation Board
  • FTDI to 10 pin adaptor with installed FT2232 module (Download LM10010 GUI Installer)
  • USB to Mini B cable
  • Software Compact Disc
GMT+8, 2024-11-26 11:53 , Processed in 0.210452 second(s), 15 queries , MemCache On.
