查看: 217|回复: 0
LPC1227 LPCXpresso 开发板
  • 签到天数: 11 天
    发表于 2013-1-30 14:28:14 | 显示全部楼层 |阅读模式
    LPC1227 LPCXpresso 开发板是针对NXP 基于ARM微控制器的最新的低成本的开发平台。The platform is comprised of a simplified Eclipse-based IDE and low-cost target boards which include an attached JTAG debugger. LPCXpresso is an end-to-end solution enabling embedded engineers to develop their applications from initial evaluation to final production.Populated with the LPC1227 to demonstrate LPC122x features, the LPCXpresso LPC1227 combines the industrial control capability of the LPC1227 and the low price point of the LPCXpresso.
    特性
    • Eclipse-based IDE using very low-cost target boards.
    • The target boards comes with an integrated JTAG Debugger. No need for a separate debug probe!
    • Easy upgrade options to full-blown suites (from Code Red) and hardware kits (from Embedded Artists).
    • End-to-end solution for creating applications all the way from evaluation through to production.
    LPC1227 LPCXpresso 开发板用户指南.pdf
    4.46 MB, 下载次数: 0
    GMT+8, 2024-11-26 11:46 , Processed in 0.112874 second(s), 16 queries , MemCache On.
