查看: 1441|回复: 0
ATAVRMC301开发板
  • 签到天数: 11 天
    发表于 2013-1-22 14:50:40 | 显示全部楼层 |阅读模式
    ATAVRMC301开发板是ATtiny861 AVR®微控制器的驱动板,此开发板可连接至通用驱动开发板来驱动MC300。This board is also designed to be connected on any other driver board which could share the same interface. Power and all signals needed for a power stage board are available on the right side of the board. Jumpers allow demonstrating sensor or sensorless modes of motor control. Finally, interface like USB or Atmel DB101 Display module is also available.Features•Motor Control device board for ATtiny861•Modular system with 2.54mm pin header connector for power board MC300•Sensor & sensorless modes capabilities•Hall sensor header, Potentiometer for motor control•Headers for Atmel® DB101 Display module•USB interface for PC connection and usage of Atmel® Motor Control Center software•ISP & debug interface for both ATtiny861 & USB device.•Electric specifications:-Supplied with Power board like MC300 from 3.3V up to 5V•Dimension: 100x100mm
    ATAVRMC301开发板用户指南.pdf
    746.55 KB, 下载次数: 0
    ATAVRMC301开发板BOM.zip
    124.11 KB, 下载次数: 0
    GMT+8, 2025-1-16 19:51 , Processed in 0.117728 second(s), 16 queries , MemCache On.
