TA的每日心情 | 开心 2013-9-2 09:06 |
签到天数: 11 天 连续签到: 1 天 [LV.3]偶尔看看II
XLP 8位开发板以超低功耗为设计理念,将休眠消耗电流低至20nA的低功耗开发平台。The board is suitable for prototyping many low power applications including RF, temperature sensors, electronic door locks, LCD , remote controls, security sensors, smart cards, and energy harvesting. The PICtail™ interface supports Microchip’s extensive line of daughter cards for easy evaluation of your next low power application.This low cost board is the ideal complement to the MPLAB® PICkit 3 or ICD 3 debugger and programmer realizing a fully-featured, economical, PIC18 or PIC16 development environment.XLP 8-bit Development Board Features:
- PIC18F87K22(128KB Flash, 80-pin PIM) installed• Supports other PIC16LF1947 (28KB Flash, 64-pin PIM) Separate/Un-programmed• Current measurement terminals allow device or board level current measurements• Expansion connector accessing full device pin-out and breadboard prototype area• Convenient connections for MPLAB PICkit 3, ICD 3 or REAL ICE for in-circuit programming and debugging• USB interface for power and PC communication• 24AA256 Low Power (100nA Sleep, 1.7V Vdd) SPI serial-EEPROM• Potentiometer (connected to 10-bit A/D, analog input channel)• Analog output temperature sensor and CTMU based diode temperature sensor• LEDs for indication• Power Options: AAA, CR2032, Energy Harvesting, USB, External, or 9V power supply
