TA的每日心情 | 开心 2013-9-2 09:06 |
签到天数: 11 天 连续签到: 1 天 [LV.3]偶尔看看II
MCP2210 评估套件是专业开发和评估MCP2210的性能的平台。The MCP2210 Motherboard is designed to work together with the MCP2210 Breakout Board. The motherboard provides the test points needed for measurements and it also contains the following SPI slave chips:- MCP23S08 – 8 bit I/O expander- MCP3204 – 4 channel, 12-bit ADC- 25LC02 – 2kbit EEPROM- TC77 – temperature sensorAll the mentioned chips are SPI slaves controlled by the MCP2210. The MCP2210 Eval Board Demo software can be used to demonstrate the MCP2210 as a USB-to-SPI (Master) device and allow I/O control. In addition, the MCP2210 Utility software allows custom device configuration. A DLL package is also available in order to allow development of custom software using the MCP2210.This Kit Contains: • 1x MCP2210 Breakout Module Board (ADM00419)• 1x MCP2210 SPI Slave Motherboard (ADM00420)• 1x Mini-USB cableFeatures: MCP2210 Breakout Board:• Small plug-in board with DIP form factor (2, 10-pin headers spaced at 600mil)• Mini-USB connector• Access to the SPI bus and all the GP signals• PICkit Serial Analyzer compatible header• 3.3 or 5V jumper selectable VDD• Able to supply up to 500mA to the rest of the system MCP2210 SPI slave Motherboard:• Socket for insertion of the MCP2210 Breakout Board• Easily accessible test points for the SPI bus and GP signals• PICkit Serial Analyzer header to access the MCP23S08• Potentiometer allows altering of voltage on the channel 1 ADC input |
