查看: 346|回复: 0
MCP3911 ADC 评估板
  • 签到天数: 11 天
    发表于 2013-1-9 10:36:16 | 显示全部楼层 |阅读模式
    MCP3911 ADC 评估板专门用于评估MCP3911 双通道ADC的性能。It also provides a development platform for 16-bit PIC-based applications, using existing 100-pin PIM systems compatible with the Explorer-16 and other high pin count PIC demo boards. The system comes with a programmed PIC24FJ256GA110 PIM module that communicates with the included PC software for data exchange and ADC configuration.This Kit Contains: • 1x MCP3911 ADC Evaluation Board for 16-Bit MCUs• 1x PIC24FJ256GA110 PIM• 1x USB cableFeatures: • Dual ADC MCP3911 output display using serial communication to PC software (Energy Management Utility)• Simultaneous 55 ksps at 95 dB SINAD performance on dual MCP3911 channels• System and ADC performance analysis through graphical PC tools showing Noise Histogram, Frequency Domain (FFT), Time domain scope plot, and statistical numerical analysis• Robust hardware design with analog grounding and analog/digital separation, allowing low noise evaluation of the MCP3911 device• Separate power supplies and power planes (4 layer board)• PICtail Plus connectors for Explorer-16 daughter board compatibility
    MCP3911 ADC 评估板用户指南.pdf
    1.58 MB, 下载次数: 1
    MCP3911 ADC 评估板电路原理图.pdf
    122.42 KB, 下载次数: 1
    MCP3911数据手册.pdf
    2.54 MB, 下载次数: 1
    MCP3911 ADC 评估板 BOM.pdf
    36.97 KB, 下载次数: 1
    GMT+8, 2024-11-26 11:40 , Processed in 0.118717 second(s), 16 queries , MemCache On.
