查看: 869|回复: 0
MCP47X6 PicTail Plus 子板
  • 签到天数: 11 天
    发表于 2013-1-6 17:08:24 | 显示全部楼层 |阅读模式
    MCP47X6 PicTail Plus 子板为您评估MCP4726, MCP4716和MCP4706 芯片的性能提供了优质的平台。This board can be controlled by the MCU of the Explorer 16 Development Board (P/N: DV164033) or by a PICkit™ Serial Analyzer. The board also provides easy access via test points to desired signals to monitor device operation. A buzzer is supplied that is connected to the output of the MCP4726, which allows generation of an audible sound. The buzzer has a volume control.This Kit Contains: • One MCP47X6 PicTail Plus Daughter BoardFeatures: • Explorer 16 Development Board Interface and Firmware• PICkit™ Serial Analyzer Interface• MCP4726, MCP4716, and MCP4706 devices• Easy access to desired signals of the MCP47x6 device
    MCP47X6 PicTail Plus 子板电路原理图.pdf
    60.23 KB, 下载次数: 0
    MCP47X6 PicTail Plus 子板用户指南.pdf
    1.13 MB, 下载次数: 0
    MCP47X6 PicTail Plus 子板物料清单.pdf
    28.01 KB, 下载次数: 0
    GMT+8, 2024-11-26 11:36 , Processed in 0.118567 second(s), 16 queries , MemCache On.
