TA的每日心情 | 开心 2013-9-2 09:06 |
签到天数: 11 天 连续签到: 1 天 [LV.3]偶尔看看II
STEVAL-MKI116V1 演示板目的是为了提供数字MEMS麦克风的解码和播放方案。The STEVAL-MKI116V1 demonstration board hosts the MP34DB01 (bottom-port digital microphone), working as a sensor, and the STM32F107RC microcontroller, working as an audio decoder. These microphones are analog-to-digital transducers. They are able to sense sound pressure and convert this signal into a digital signal using the PDM technique. The STM32 microcontroller decodes the PDM signal coming from the microphones and streams the audio via the USB.The STEVAL-MKI116V1 demonstration board is a sound card automatically recognized by the PC as an audio device. Connection is made through a USB cable which also supplies the board and then streams the collected audio.
Key Features
- Powered and connected to PC through USB
- Sound card automatically recognized by the PC as an audio device
- The onboard microphones are digital MEMS devices
- MEMS microphones provide a high frequency data stream (1 to 3.25 MHz) of 1-bit digital samples (PDM technique)
- Audio collected from the microphones is sent to the PC through the USB
- LED status indicator
- RoHS compliant
