查看: 174|回复: 0
CR95HF演示板
  • 签到天数: 11 天
    发表于 2012-12-17 16:21:31 | 显示全部楼层 |阅读模式
    CR95HF演示板用于评估ST CR95HF 13.56 MHz多接触式收发器的性能,它包括一个使用USB接口与CR95HF 主机演示软件连接的电路板。The DEMO-CR95HF-A is powered through the USB bus and no external power supply is required. It includes a CR95HF contactless transceiver, a 47 x 34 mm 13.56 MHz inductive etched antenna and its associated tuning components.By default, the CR95HF communicates with the STM32F103CB 32-bit MCU via the SPI bus. The interface can then be changed to UART.At the end of the initialization, the DEMO-CR95HF-A launches a tag tracking operation. When an RFID or NFC tag is identified, the LED is turned on.
    Key Features
    • Ready to use printed circuit board
      • CR95HF cut 1.2 multiprotocol transceiver IC
      • STM32F103CB 32-bit microcontroller
      • 47 x 34 mm 13.56 MHz inductive etched antenna and tuning components
      • USB-B connector for communication with host PC and demonstration board powering
      • USB connect/disconnect jumper (must be left in default state)
      • LED indicating the presence of an RFID or NFC tag
      • Microcontroller reset button
      • JTAG connector for microcontroller firmware upgrade and debug
    • USB cable
    • Demonstration tags
      • ISO15693 tag: LRI2K mounted on a 45 x 75 mm antenna
      • ISO 15693 dual interface EEPROM memory: M24LR64-R mounted on a 15 x 15 mm double side etched antenna
    • Associated Firmware and PC software
      • On-board demonstration firmware to communicate with the host PC through the USB bus.
      • The CR95HF developement software enable discovery and useof all the functionalities of the CR95HF transceiver.
      • The M24LRXX application software is dedicated to the Dual interface EEPROM and ISO/IEC 15693 contactless tag.
    CR95HF演示板数据资料.pdf
    119.97 KB, 下载次数: 0
    CR95HF演示板用户指南.pdf
    750.15 KB, 下载次数: 0
    CR95HF演示板软件使用指南.pdf
    1.02 MB, 下载次数: 0
    CR95HF演示板电路原理图.pdf
    48.56 KB, 下载次数: 0
    CR95HF演示板物料清单.pdf
    37.38 KB, 下载次数: 0
    GMT+8, 2024-11-26 10:23 , Processed in 0.117013 second(s), 16 queries , MemCache On.
