TA的每日心情 | 开心 2013-9-2 09:06 |
签到天数: 11 天 连续签到: 1 天 [LV.3]偶尔看看II
M24LR64-R 数据采集板是一个现成的印刷电路板,突出显示双接口 M24LR64-R EEPROM 芯片通过总线连接到电路板上STM8L101K3 8位微控制器和20毫米×40毫米13.56MHz射频天线。STM8L101K3同样也与STTS75温度传感器和CR2330可充电电池相连接。The DATALOG-M24LR-A allows system designers to start developing a standalone or an embedded datalogger.The DATALOG-M24LR-A reference board is supported by ST DEVKIT-M24LR-A, STARTKIT-M24LR-A and DEMOKIT-M24LR-A evaluation kits, for which a demonstration software is available.
Key Features
- Ready-to-use printed circuit board (PCB) with:
- 20 mm x 40 mm 13.56 MHz inductive antenna etched on the PCB
- STM8L101K3 8-bit microcontroller
- STTS75 temperature sensor
- SWIM connector for microcontroller firmware upgrade
