UC3-A3 Xplained 工具包是适用于 AVR UC3A 的 MCU 板。它包含 AT32UC3A3256(带高速 USB)和其他可演示器件特性的元件。The Atmel® UC3-A3 Xplained evaluation kit is a hardware platform for evaluating the Atmel AT32UC3A3256 microcontroller. The kit offers a range of features that enable the Atmel AVR® UC3 user to get started using AVR UC3 peripherals right away and understand how to integrate the AVR UC3 device in their own design.NOTE: The UC3-A3 Xplained is suited for evaluation of both UC3A3 and UC3A4 microcontrollers. The two series share the same peripherals, except that the UC3A3 features a External Bus Interface (EBI) while the UC3A4 does not.The AES peripheral of the UC3A3S/A4S and the Audio peripheral of the UC3A3AU are not supported by the device on this board. To evaluate these features please use the EVK1104S and EVK1104AU respectively. 关键特性
Transfer data over the high-speed USB interface
Read temperature sensor with the ADC
Use the Atmel QTouch library to detect touches on the touch button and slider
Read/write data to the 64Mbit SDRAM
Use PWM as input to an analog filter and ADC to measure the filter response
1 push button to interact with the microcontroller
4 LEDs to show status information
Program the kit via USB bootloader or an Atmel programmer
