UC3-L0 Xplained 工具包是适用于 AVR UC3L 的 MCU 板。它包含 picoPower® AT32UC3L064 和其他可演示器件特性的元件。 The Atmel® UC3-L0 Xplained evaluation kit is a hardware platform for evaluating the Atmel AT32UC3L064 microcontroller. The kit offers a range of features that enable the Atmel AVR® UC3 user to get started using AVR UC3 peripherals right away and understand how to integrate the AVR UC3 device in their own design.NOTE: The UC3-L0 Xplained is suited for evaluation of both UC3L0 and UC3L4 microcontrollers. The two series share the same peripherals, except that the UC3L4 features a USB Full-speed USB Device module while the UC3L0 does not.关键特性
Use the Atmel QTouch library to detect touches on the touch button and slider
Read temperature sensor with the ADC
Use PWM as input to an analog filter and ADC to measure the filter response
One push button to interact with the microcontroller
One RGB LED to show status information
Program the kit via bootloader or an Atmel programmer
