TA的每日心情 | 开心 2013-9-2 09:06 |
签到天数: 11 天 连续签到: 1 天 [LV.3]偶尔看看II
MEGA-1284P Xplained 工具包是适用于 megaAVR 的 MCU 板。它包含 ATmega1284P 和其他可演示器件特性的元件。 The Atmel MEGA-1284P Xplained evaluation kit is a hardware platform for evaluating the Atmel ATmega1284P microcontrollers. The MEGA-1284P Xplained contain one QTouch button sensor, three mechanical buttons, four LEDs, 3 analog sensors, a UART to USB bridge. The AVR Xplained expansion headers provide easy access to analog and digital I/O pins. The board is powered by the USB cable and equipped with the standard 10-pin JTAG header that connects to the full range of AVR debuggers.NOTE: The MEGA-1284P Xplained can be used to evaluate the ATmega164/324/644/1284 microcontrollers and the A, P and PA versions of these devices. These devices shares the same peripherals, and differ only in memory size electrical characteristics such as power consumption. The peripherals are in general functional compatible with other megaAVR devices, and the MEGA-1284P Xplained can therefore be used as a general evaluation platform for other megaAVRs as well. Alternatively the STK600 can be used if specific devices needs to be evaluated.关键特性
- Atmel ATmega1284P microcontroller
- Read temperature sensor with the ADC
- Read light sensor with the ADC
- Use the Atmel QTouch library to detect touches on the touch button
- Use PWM as input to an analog filter and ADC to measure the filter response
- 3 push buttons to interact with the microcontroller
- 4 LEDs to show status information
- Board controller that routes data from the ATmega1284P UART to the PC via USB
- Program the kit via bootloader or an Atmel programmer
- Expand the board with Xplained top modules
