查看: 160|回复: 0
XMEGA-A3BU Xplained 工具包
  • 签到天数: 11 天
    发表于 2012-12-8 13:14:02 | 显示全部楼层 |阅读模式
    XMEGA-A3BU Xplained 工具包是适用于 AVR XMEGA 的 MCU 板。它包含 ATxmega256A3BU 和其他可演示器件特性的元件。The Atmel AVR Xplained kits are great platforms for early evaluation of the capabilities offered by the Atmel AVR microcontrollers. The XMEGA-A3BU Xplained contain one QTouch button sensor, three mechanical buttons, two LEDs, 3 analog sensors, a USB port, battery backup system and a 128x32 pixel FSTN LCD display.The AVR Xplained expansion headers provide easy access to analog and digital I/O pins. The board is powered by the USB cable and equipped with the standard 10-pin JTAG header that connects to the full range of AVR debuggers.NOTE: The XMEGA-A3BU Xplained can be used to evaluate the XMEGA A1/A3/A4 and A1U/A3U/A4U devices. The devices shares the same peripherals, but the A1, A3 and A4 devices has different pin count and hence different number of each peripherals. The A3BU devices features Battery Back-up for the RTC peripheral, which the other devices does not. The XMEGA A1 devices features an External Bus Interface (EBI) which the A3BU devices does not. To evaluate the EBI it is recommended to use the XMEGA-A1 Xplained.关键特性
    • Atmel ATxmega256A3BU microcontroller
    • Keep RTC running in the backup system while main power is absent
    • Display data on the 128x32 pixels of the FSTN LCD display
    • Read temperature sensor with the ADC
    • Read light sensor with the ADC
    • Use the Atmel QTouch library to detect touches on the touch button
    • Read/write data to the 64Mbit Atmel DataFlash
    • 3 push buttons to interact with the microcontroller
    • 4 LEDs to show status information
    • Program the kit via USB bootloader or an Atmel programmer
    • Expand the board with Xplained top modules
    购买XMEGA-A3BU Xplained:https://www.eeboard.com/shop/?c=products&a=view&id=210
    XMEGA A3BU Xplained入门指南.pdf
    295.7 KB, 下载次数: 2
    XMEGA A3BU Xplained 软件用户指南.pdf
    253 KB, 下载次数: 2
    XMEGA-A3BU Xplained 工具包硬件用户指南.pdf
    445.12 KB, 下载次数: 1
    XMEGA-A3BU Xplained原理图.pdf
    4.07 MB, 下载次数: 1
    XMEGA-A3BU Xplained PCB版图.zip
    3.33 MB, 下载次数: 1
    ATxmega256A3BU数据手册.pdf
    4.26 MB, 下载次数: 1
    XMEGA A3BU Xplained USB驱动.zip
    1 KB, 下载次数: 1
    Atmel DFU编程工具FLIP.zip
    5.59 MB, 下载次数: 2
    GMT+8, 2024-11-26 10:15 , Processed in 0.104695 second(s), 16 queries , MemCache On.
