TA的每日心情 | 开心 2013-9-2 09:06 |
签到天数: 11 天 连续签到: 1 天 [LV.3]偶尔看看II
MAX16952评估套件是包含评估同步降压控制器MAX16952所有必要组成部件,如完全组装和测试电路板。
The device is available in a 16-pin TSSOP package and features an exposed pad for enhanced thermal dissipation.
The EV kit requires a 6V to 36V power supply for normal operation. The EV kit output is configured to 5V and can deliver up to 5A output current. The EV kit can be easily reconfigured to operate the controller in continuous PWM mode, SKIP mode, or external synchronization operation. The controller switching frequency is set to 2.2MHz. The EV kit includes a jumper to enable the circuit and an LED to monitor the power-good output.
关键特性
- 6V to 36V Input Range
- 5V at Up to 5A Output
- 2.2MHz Switching Frequency
- Selectable Forced Fixed-Frequency PWM Mode, SKIP Mode, or External Synchronization
- Power-Good LED Indicator
- Enable Input
- Cycle-by-Cycle Current Limit and Thermal Protection
- Proven PCB Layout
- Fully Assembled and Tested
应用/使用
