查看: 326|回复: 0
Hitex LPC2939 评估板
  • 签到天数: 11 天
    发表于 2012-11-22 14:25:57 | 显示全部楼层 |阅读模式
    Hitex LPC2939 评估板让您快速简易地评估LPC293x系列微控制器。Populated with the LPC2939 to demonstrate LPC293x features, the LPC2939 board allows the evaluation of the optimized power consumption and the memory capability of the LPC2939.
    Features
    • Support of 2 CAN and 2 RS232 ports
    • external SRAM 512k x 8 (limitation for evaluation board V1.0)
    • 2 x small 7-segment LEDs attached to port pins
    • 3 buttons for reset, IRQ and port pin
    • JTAG debugger support with JTAG connector
    • 2 x 24 pin connector for BLDC motor add-on board
    • USB powered or alternative external power via BNC connector
    • power, reset and enumeration LED indicator
    GMT+8, 2024-11-26 12:20 , Processed in 0.114650 second(s), 15 queries , MemCache On.
