查看: 252|回复: 0
TPS51511EVM 评估模块
发表于 2012-11-20 10:15:42 | 显示全部楼层 |阅读模式
 TPS51511EVM 演示了使用的TPS51511开关稳压器,在1.2 Vout下的 15 A开关电源, 1.2 Vout下2 A  LDO。The TPS51511 is a 350 kHz D-CAP-mode synchronous switcher with a 2 A, source-only low drop-out (LDO) regulator. It is specifically designed for low cost/low noise/low external-component count power systems for GPU applications. The integrated 'OD' switch in the buck controller supports dynamic output voltage change.
特性
  • Switcher Vin 3 V to 25 V
  • Output current 15 A
  • Operating frequency 350 kHz
  • 2 A LDO Regulator
TPS51511EVM用户指南.pdf
300.28 KB, 下载次数: 0
GMT+8, 2024-11-26 12:36 , Processed in 0.111043 second(s), 16 queries , MemCache On.
