查看: 252|回复: 0
串行端口扩展器评估套件
  • 签到天数: 11 天
    发表于 2012-11-19 14:10:11 | 显示全部楼层 |阅读模式
    CY3242-IOX Rev. A Kit Contents:
    • I2C Port Expander Evaluation Board
    • I2C-USB Bridge
    • USB Cable (6ft/2m)
    • 5V-2A DC Power Supply
    • Strip of 10 Post Shunts
    • I2C Port Expander Evaluation Kit Mini-CD
    Hardware DescriptionThe I2C Port Expander Evaluation Kit allows you to easily assess the following value propositions of Cypress' I2C port expander solutions:
    • Integration
    • Flexibility
    • Compatibility
    Cypress' three I2C port expander devices (CY8C9520, CY8C9540, CY8C9560) have the following features:
    • Three compatible part families that seamlessly scale up or down
    • 20, 40, or 60 individually configurable IO (widest range of IOs in the industry)
    • 4, 8, or 16 PWMs that map to any pin or multiple pins (Widest range of PWMs in the industry)
    • 3 Kbytes, 11 Kbytes, or 27 Kbytes of User EEPROM (largest amount of user-accessible serial EEPROM in the industry)
    • I2C communication up to 400 kHz
    • Industrial temp range: -40 to 85 degrees Celsius
    • Operating voltage: 3.0V - 5.25V
    • 28-SSOP/48-SSOP/100-TQFP package options
    Bottom line: One Cypress I2C Port Expander device replaces multiple port expander ICs from other vendors and flexibly integrates IO expansion, PWM functions and user EEPROM.
    This kit also includes the I2C-USB Bridge, which allows hardware and software debugging of PSoC applications by seamlessly connecting your PC's USB port to your application's I2C interface.
    串行端口扩展器评估套件入门指南.pdf
    107.57 KB, 下载次数: 0
    串行端口扩展器评估套件用户指南.pdf
    386.46 KB, 下载次数: 0
    GMT+8, 2024-11-26 12:46 , Processed in 0.119504 second(s), 16 queries , MemCache On.
