查看: 260|回复: 0
CY3674 EZ-USB FX1开发套件
  • 签到天数: 11 天
    发表于 2012-11-16 15:04:42 | 显示全部楼层 |阅读模式
    EZ-USB FX1(TM) 系列的开发套件为系列中的所有产品加快硬件和驱动程序的开发提供完了完善的硬件和软件解决方案。
    Cypress includes an evaluation version of the 8051 Keil Software Tools in the Full Speed USB 2.0 development kit. The evaluation version of the C-Compiler lets the designer write 8051 microcontroller applications in C and still get the efficiency and speed of assembly language. Advanced features from Keil tools include the ability to single step through code. This makes it easy to detect errors, handle source level debugging, and set breakpoints. With the ability to debug code one line at a time and to quickly compile and one-step download new code, developers have a more efficient means to complete firmware faster than using emulators. The supplied Keil tools are fully functional, but are limited in object size to 4 kilobytes.The kit includes the following:
    • EZ-USB development board with CY7C64713-128AXC
    • Peripheral board for prototyping
    • USB cable
    • An RS232 9-pin to 9-pin cable
    CY3674 EZ-USB FX1开发套件用户指南.pdf
    3.87 MB, 下载次数: 0
    CY3674 EZ-USB FX1开发套件入门指南.pdf
    157.27 KB, 下载次数: 0
    GMT+8, 2024-11-26 12:41 , Processed in 0.114616 second(s), 16 queries , MemCache On.
