查看: 278|回复: 0
TPS51120评估模块
发表于 2012-11-16 09:30:17 | 显示全部楼层 |阅读模式
 TPS51120EVM-001评估模块使用 TPS51120,高效率,双输出同步降压转换器提供5 V 6 A和3.3 V , 6 A 8 V至25 V输入。The user’s guide describes the TPS51120EVM-001 performance in D-CAP™ mode and RDS(on) current sensing.The TPS51120 is a highly sophisticated dual current mode synchronous step-down controller. It is a full featured controller designed to run directly off three to four-cell Li-ion battery and provide high power and 5 V and/or 3.3 V standby regulation for all the downstream circuitry in a notebook computer system.High current, 100 mA, 5 V or 3.3 V on-board linear regulators have glitch-free switch over function to SMPS and can be kept alive independently during standby state. The pseudo-constant frequency adaptive on-time control scheme supports full range of current mode operation including simplified loop compensation, ceramic output capacitors as well as seamless transition to reduced frequency operation at light-load condition. Optional D-CAP™ mode operation optimized for SP-CAP or POSCAP output capacitors allows further reduction of external compensation parts.
TPS51120EVM-001用户指南.pdf
316.07 KB, 下载次数: 0
GMT+8, 2024-11-26 12:23 , Processed in 0.124310 second(s), 16 queries , MemCache On.
