查看: 283|回复: 0
TPS7A8101评估模块
发表于 2012-11-19 09:23:17 | 显示全部楼层 |阅读模式
  TPS7A8101EVM-093评估模块帮助设计者评估 TPS7A8101低噪声,高带宽,高PSRR , 1A低压降线性稳压器。The EVM is a stand alone evaluation module containing a low-dropout regulator IC for adjustable voltage regulation at 1A, input and output capacitors for stable operation, noise reduction capacitor and header-connectors for easy connection to external test and application circuitry.
特性
  • Input Voltage as low as 2.2V
  • 170mV dropout @ 1A
  • Adjustable output from 0.8V to 6.0V
  • Protections: Over current and Over temperature
  • Enable pin
  • Wide-Bandwidth High PSRR
  • Low-Noise 3mm x 3mm SON-8 DRB Package
TPS7A8101EVM-093用户指南.pdf
1.13 MB, 下载次数: 0
GMT+8, 2024-11-26 12:37 , Processed in 0.111615 second(s), 16 queries , MemCache On.
