TPS54295EVM-057评估模块是完全组装和测试的电路,用于评估TPS54295双通道2A 输出,同步降压SWIFT转换器。The EVM operates from a 4.5V to 18V input and generates output voltages of 1.5V and 3.3V with a switch current limit of 2A minimum.
特性
D-CAP2 Mode Control
Wide Input Voltage Range: 4.5V to 18V
Output Voltage Range: 0.76 V to 7.0V
Low-Side RDS(on) Loss-Less Current Sensing
Adjustable Soft Start
Non-Sinking Pre-Biased Soft Start
700kHz Switching Frequency
Optimized Efficiency at Light and Heavy Loads with Auto-Skip Function
Cycle-by-Cycle Over-Current Limiting Control
OCL/OVP/UVP/UVLO/TSD Protections
Adaptive Gate Drivers with Integrated Boost PMOS Switch
