TA的每日心情 | 开心 2013-9-2 09:06 |
签到天数: 11 天 连续签到: 1 天 [LV.3]偶尔看看II
STEVAL-IHT001V2 恒温器套件提供了一个功能强大和低成本的控制冰箱、冰柜、冰箱/冰柜组合的ST解决方案(微控制器和交流开关)。Basic, defrost, and air circulation versions are configurable in order to address the low-end and medium-end cooling appliances market. It allows the control of a single-phase induction motor and a light bulb, and optionally, a defrost resistor and a fan, working on 220/240 VRMS, 50/60 Hz mains voltage. The thermostat kit is operational with 100/120 V RMS 50/60 Hz but the supply capacitor value must be modified.The board can operate in an ambient temperature range from 0 °C to 60 °C. The exact maximum temperature depends on the power of the loads. For demonstrative purposes a graphic user interface (GUI) has been developed. The connection between the PC and STM8S microcontroller, the MCU performing thermostat regulation, is achieved through a USB bus. As the STM8S is a low-cost MCU without an embedded USB peripheral, an additional MCU (STM32) has been used as a bridge between the PC and STM8S MCU, for demonstrative purposes only.关键特性
- Low-cost solution for spark-free thermostats:
- No need for a sealed version
- Low-cost STM8S microcontroller for thermostat control
- Low-cost capacitive power supply
- High efficiency:
- Refrigerator consumption reduction by adjusting and reducing the hysteresis threshold of the temperature
- Improved efficiency by turning on the defrost resistor only when it's useful and not at each OFF cycle of the compressor (as done in some mechanical thermostats)
- High system immunity:
- Overvoltage protected ACS switches: ACST610-8FP for compressor control, ACS110-7SN for defrost resistor and ACS102-6TA for light bulb and fan
- Class A criteria for IEC 61000-4-4 up to above 3 kV levels
- Flexibility:
- Development: program setting with PC interface to change firmware variables
- Industrialization: end-of-production MCU programming thanks to FLASH, for soft upgrade and efficient MCU stock management
- RoHS compliant
下载连接:
STEVAL-IHT001V2 恒温器套件用户指南
STEVAL-IHT001V2 恒温器套件简介 |
