查看: 390|回复: 0
TPS40180EVM评估模块
发表于 2012-10-16 10:22:01 | 显示全部楼层 |阅读模式
TPS40180EVM 评估模块是可堆叠单相同步降压转换器。The TPS40180EVM evaluation module (EVM) is a stackable single phase synchronous buck converter and is designed to demonstrate the TPS40180 in a typical regulated bus to low-voltage application while providing a number of test points to evaluate the performance of the TPS40180 in a given application.The EVM delivers 1.5 V at 20 A. Each EVM is stackable with another EVM to provide higher output current. The module uses the TPS40180 Synchronous Buck Controller. TPS40180EVM is designed to use a regulated 10.8 V to 13.2 V bus to produce a high current, regulated output. The output is capable of supplying up to 20 A of load current.
特性
  • 10.8 V - 13.2 V input range
  • 1.5 V fixed output
  • 20 A DC Steady State Current
  • 285 kHz switching frequency per phase
  • Single Main Switch N-channel MOSFET and Two Synchronous Rectifier N-channel MOSFETs per Phase
  • Stackable With Another EVM to Provide Higher Output Current
  • Convenient Test Points for Probing Critical Waveforms and Non-Invasive Loop Response Testing
下载连接:
TPS40180EVM用户指南
GMT+8, 2024-11-26 14:45 , Processed in 0.110607 second(s), 15 queries , MemCache On.
