查看: 227|回复: 0
TPS54061 评估模块
发表于 2012-10-15 14:49:45 | 显示全部楼层 |阅读模式
TPS54061EVM-142 评估模块帮助开发者评估 TPS54061 同步降压快速转换器的性能.
The EVM operates from an 8V to 60V input (24V nominal) and provides a 3.3V output at 200mA.
特性
  • 4.7 V to 60 V Input Supply Voltage
  • Integrated High Side and Low Side N-Channel MOSFET
  • Fixed Frequency Peak Current Mode Control
  • 1.4 μA Shutdown Current
  • 90 μA No Load Quiescent Operating Current
  • Enable with Hysteresis (for Adjustable Input Voltage UVLO)
  • 50 kHz to 1.1MHz Adjustable Switching Frequency using an external Resistor
  • Synchronizes to External Clock
  • 0.8 V Internal Voltage Reference at 2% Accuracy
  • Cycle by Cycle Current Limit, Thermal and Frequency Fold Back Protection
  • Internal Slow Start
下载连接:
TPS54061EVM-142用户指南
GMT+8, 2024-11-26 14:34 , Processed in 0.112325 second(s), 15 queries , MemCache On.
