查看: 317|回复: 0
TPS84410评估模块
发表于 2012-10-15 13:24:41 | 显示全部楼层 |阅读模式
 TPS84410EVM-001 是完全组装和经过测试的,用于评估 TPS84410 4 2.95V to 6V 输入, 4A输出降压集成电源解决方案。The output voltage can be selected from four preset values using a jumper (3.3V, 2.5V, 1.8V, 1.2V, and 0.8V) and has an adjustable switching frequency of 500 kHz to 2 MHz. Solder pads and jumpers are available to configure the EVM to specific requirements.
特性
  • Compatible with 3.3V and 5V input bus applications
  • 0.8V internal voltage reference ±1% accurate over temperature
  • Adjustable slow start and power sequencing
  • Adjustable input voltage UVLO
  • Output under-voltage and overvoltage power good output
  • Cycle by cycle current limit, frequency foldback, and thermal protection
下载连接:
TPS84410EVM-001用户指南
GMT+8, 2024-11-26 14:43 , Processed in 0.110551 second(s), 15 queries , MemCache On.
