MCP73831 评价工具包中提供了两个评估板。评估板用于评估对简单的、 独立的、 线性充电的单个锂 / 锂聚合物电池的充电性能 。Each board design provides constant current charging followed by constant voltage charging with automatic charge termination. In addition, the MCP73831-2AC board provides preconditioning of deeply depleted cells.Each board design provides evaluation of the MCP73831 in two package options: a SOT23-5 and a 2 mm x 3 mm, 8-Lead DFN for higher power handling capability.Features:
4.2V Charge Voltage
Programmable Fast Charge Current up to 500 mA
Preconditioning of deeply depleted cells (MCP73831-2AC)
