查看: 213|回复: 0
MCP7386X 锂离子电池充电器评估板
  • 签到天数: 11 天
    发表于 2012-10-12 10:07:16 | 显示全部楼层 |阅读模式
    MCP7386X评估板用以评估简单,独立的单/双Lithium-Ion/Lithium-Polymer电池包(不包括电池组)的线性充电性能。The board design provides constant current charging followed by constant voltage charging with automatic charge termination. As provided, the MCP7386X Evaluation Board is set for a fast charge current level of 1.1A for single cell applications. The MCP73861 is equipped with shutdown control, status indicator, fault indicator, safety timer, and continuous cell temperature monitor. For dual cell applications, the MCP73862 or the MCP73864 can be substituted for the MCP73861.Features:
    • Evaluation of MCP7386X devices in 4mm x 4mm, 16-Lead QFN packages
    • Simple Stand-Alone Operation or Microcontroller Compatible
    • Powered from external bench supply or wall cube
    • Surface-Mount Design
    • Fully Assembled and Tested
    下载连接:
    MCP7386X 锂离子电池充电器评估板用户指南
    GMT+8, 2024-11-26 14:51 , Processed in 0.113060 second(s), 15 queries , MemCache On.
