查看: 134|回复: 0
KIT33811EGEVBE评估板
  • 签到天数: 11 天
    发表于 2012-10-10 16:38:10 | 显示全部楼层 |阅读模式
    KIT33811EGEVBE评估套件采用MC33811的电磁监控器集成电路(IC)。 MC33811是一种5信道螺线管监控器IC,用于验证正确的电气和机械的电磁操作。该IC为通信和设置故障配置了5个电磁阀驱动电压监测阶段和一个串行外设接口(SPI)。Additionally, the kit features the MC33810, an eight channel output driver IC. The  4 low side drivers are suitable for driving fuel injectors, solenoids, lamps, and relays. The four gate pre-drivers can function either as ignition IGBT gate pre-drivers or as general purpose MOSFET gate pre-drivers.Features
    • Typical operating voltage range, 10.5 < VPWR < 15.5 volts
    • Interfaces to 3.3 and 5 volt microprocessors via SPI protocol
    • Reset pin to initialize all 5 fault outputs
    • Internal Voltage Regulator
    • Internal oscillator
    • Unique solenoid current profile detection circuitry
    KIT33811EGEVBE评估板用户指南.pdf
    914.95 KB, 下载次数: 0
    MC33811 数据手册.pdf
    966.69 KB, 下载次数: 0
    GMT+8, 2024-11-26 15:40 , Processed in 0.126014 second(s), 16 queries , MemCache On.
