查看: 300|回复: 0
KIT34671EPEVBE评估板
  • 签到天数: 11 天
    发表于 2012-10-10 15:21:15 | 显示全部楼层 |阅读模式
    KIT34671EPEVBE评估套件采用MC34671,这是一个符合成本效益的完全集成的锂离子或锂聚合物电池充电器。它容忍高达28V的输入电压,从而消除了在手持设备所需的输入过电压保护电路。一个充电周期包括涓流,恒流(CC)和恒压(CV)充电模式。The constant-current (CC) is programmable up to 600mA, with an external resistor.The constant voltage is fixed at 4.2V. The trickle charge current is preset to 20% of the CC current when the battery voltage is lower than the trickle-charge threshold. The end-of-charge (EOC) current threshold is preset to 10% of the CC current to save board space and cost. A charge-current thermal foldback feature limits the charge current when the IC internal temperature rises to a preset threshold.The MC34671 has a 2.6V falling power-on-reset (POR) threshold, making it perfect to work with current-limited power supplies. Three indication pins (PPR, CHG, and FAST) can be simply interfaced to a microprocessor or LEDs. When no power supply is connected, or when disabled, the charger draws less than 1.0µA leakage current from the battery.
    Features
    •  No external MOSFET, reverse-blocking diode, or current-sense resistor are required
    •     Guaranteed maximum 600mA programmable charge current
    •     ±0.7% voltage accuracy over -20°C to 70°C
    •     ±5% current accuracy over -40°C to 85°C
    •     28V maximum voltage for the power input with 11V over-voltage protection threshold
    •     2.6V minimum input operating voltage
    •     Trickle charge for fully discharged batteries
    •     Charge current monitor
    •     Charge current thermal foldback
    KIT34671EPEVBE评估板用户指南.pdf
    388.11 KB, 下载次数: 0
    MC34671 数据手册.pdf
    596.75 KB, 下载次数: 0
    GMT+8, 2024-11-26 15:27 , Processed in 0.118273 second(s), 16 queries , MemCache On.
