查看: 207|回复: 0
KIT33887EKEVBE评估板
  • 签到天数: 11 天
    发表于 2012-10-10 10:18:45 | 显示全部楼层 |阅读模式
    KIT33887EKEVBE评估板采用MC33887单片电源IC,包括控制逻辑,电荷泵,门驱动器,以及低的RDS(on)MOSFET。It is designed to drive inductive loads with RMS currents up to 5.2 A, in both directions. In addition, the current drive can be pulse width modulated (PWM) at frequencies up to 20 kHz. An internal current mirror circuit provides a proportional (1/375 th ) sample of the output current, which may be used to provide feedback or load information to a microcontroller's A/D input.
    特性:
    • Fully specified operation 5.0 V to 28 V
    • Limited operation with reduced performance up to 40 V
    • 120 mΩ RDS(ON) typical H-Bridge MOSFETs
    • TTL/CMOS compatible inputs
    • PWM frequencies up to 10 kHz
    • Active current limiting (regulation)
    • Fault status reporting
    • Sleep mode with current draw ≤50 μA (inputs floating or set to match default logic states)
    KIT33887EKEVBE评估板用户指南.pdf
    1.61 MB, 下载次数: 0
    MC33887 数据手册.pdf
    1008.7 KB, 下载次数: 0
    GMT+8, 2024-11-26 15:35 , Processed in 0.117018 second(s), 16 queries , MemCache On.
