查看: 249|回复: 0
KIT33932VWEVBE评估板
  • 签到天数: 11 天
    发表于 2012-10-9 16:44:20 | 显示全部楼层 |阅读模式
    KIT33932VWEVBE评估板用于评估MC33932的特性,MC33932是散热增强型封装的单片电路H桥功率IC。The 33932 has two independent monolithic H-Bridge Power ICs in the same package. They are designed primarily for automotive electronic throttle control, but are applicable to any low-voltage DC servo motor control application within the current and voltage limits stated in this specification.Each H-bridge in the 33932 is able to control inductive loads with currents up to 5.0 A peak. RMS current capability is subject to the degree of heatsinking provided to the device package. Internal peak-current limiting (regulation) is activated at load currents above 6.5 A ±1.5 A. Output loads can be pulse width modulated (PWM-ed) at frequencies up to 11 kHz. A load current feedback feature provides a proportional (0.24% of the load current) current output suitable for monitoring by a microcontroller’s A/D input. A Status Flag output reports under-voltage, over-current, and over-temperature fault conditions.
    特性
    • 8.0 to 28 V continuous operation (transient operation from 5.0 to 40 V)
    • 235 mΩ maximum RDS(ON) @ 150°C (each H-Bridge MOSFET)
    • 3.0 V and 5.0 V TTL / CMOS logic compatible inputs
    • Over-current limiting (regulation) via internal constant-off-time PWM
    • Output short-circuit protection (short to VPWR or GND)
    • Temperature-dependant current-limit threshold reduction
    • All inputs have an internal source/sink to define the default (floating input) states
    • Sleep Mode with current draw < 50 μA (each H- Bridge)
    KIT33932VWEVBE评估板用户指南.pdf
    417.76 KB, 下载次数: 0
    MC33932数据手册.pdf
    961.39 KB, 下载次数: 0
    GMT+8, 2024-11-26 15:44 , Processed in 0.115776 second(s), 16 queries , MemCache On.
