TA的每日心情 | 开心 2013-9-2 09:06 |
签到天数: 11 天 连续签到: 1 天 [LV.3]偶尔看看II
KIT33812EKEVBE评估板支持MC33812, MC33812是发动机控制模拟电源IC,适用于摩托车及其他单/双气缸引擎控制应用。
特性
- Designed to operate over the range of ~4.7 V ≤ VPWR ≤ 36 V
- Fuel Injector driver - Current Limit - 4.0 A Typical
- Ignition pre-driver can drive IGBT or Darlington bipolar junction transistors
- Ignition pre-driver has independent high and low side outputs
- Relay driver - Current Limit - 4.0 A Typical
- Lamp driver- Current Limit - 1.5 A Typical
- All external outputs protected against short to battery, over-current
- Ignition and other drivers protected against over-temperature
- Interfaces directly to MCU using 5.0 V parallel interface
- VCC voltage pre-regulator provides +5.0 V power for the MCU
- MCU Power On RESET generator
- MCU watchdog timer circuit with parallel refresh/time setting line
- Independent fault annunciation outputs for ignition and injection
- ISO-9141 K-Line transceiver for communicating diagnostic messages
