查看: 149|回复: 0
KIT34700EPEVBE评估板
  • 签到天数: 11 天
    发表于 2012-10-9 14:00:24 | 显示全部楼层 |阅读模式
    KIT34700EPEVBE评估板突出了MC34700四个输出电源完全集成的高性能开关降压稳压器,包含LDO和监督的电路的特性。All switching regulators are voltage mode control and feature external compensation for greater choice in performance and external components selection.DC/DC1 is a non-synchronous converter and can operate from an external wide input supply (9-18V) and utilizes a feed-forward circuit, DC/DC 2 and 3 are both synchronous and can feed off either DC/DC1, or other available rails. The integrated LDO can be optimized to feed off either DC/DC1, 2 or 3, depending on the voltages and load currents of the application.Applications include: set top boxes and receivers, cable modems, and telecom and line cards.特性:Three switching regulators, two of which are synchronousLow-dropout linear regulatorHigh accuracy voltage outputs (±1%)User configurable power-up sequencingCycle by cycle current limit and short-circuit protectionThermal shutdown protectionOver-voltage, under-voltage, and over-current protectionSupervisory functionsActive high power-good output signalActive high enable inputs
    KIT34700EPEVBE开发板用户指南.pdf
    766.52 KB, 下载次数: 0
    MC34700 数据手册.pdf
    1.51 MB, 下载次数: 0
    GMT+8, 2024-11-26 15:52 , Processed in 0.114093 second(s), 16 queries , MemCache On.
