TA的每日心情 | 开心 2013-9-2 09:06 |
签到天数: 11 天 连续签到: 1 天 [LV.3]偶尔看看II
KIT34717EPEVBE评估板突出了MC34717EP的特性功能,MC34717EP是一个高度集成、节省空间、低成本、双通道同步降压型开关稳压器,并具有集成的N沟道功率MOSFET。It is a high performance dual point-of-load (PoL) power supply with many desired features for the 3.3 V and 5.0 V environments. Both channels can provide up to 5.0 A of continuous output current capability with high efficiency and tight output regulation. The second channel has the ability to track an external reference voltage in different configurations. The MC34717EP offers the designer the flexibility of many control, supervisory, and protection functions to allow for easy implementation of complex designs.
特性:
- 50 mΩ Integrated N-Channel Power MOSFETs
- Input Voltage Operating Range from 3.0 V to 6.0 V
- ±1 % Accurate Output Voltages, Ranging from 0.7 V to 3.6
- The Second Output Has Voltage Tracking Capability in Different Configurations
- Programmable Switching Frequency Range from 200 kHz to 1.0 MHz
- Programmable Soft Start Timing
- Over Current Limit and Short Circuit Protection
- Thermal Shutdown
- Output Overvoltage and Undervoltage Detection
- Active Low Power Good Output Signal
