查看: 160|回复: 0
KIT33988CEVBE评估板
  • 签到天数: 11 天
    发表于 2012-10-8 14:42:16 | 显示全部楼层 |阅读模式
    KIT33988CEVBE评估板支持33988的应用,33988是双向保护8.0mΩ硅型开关,在电源管理应用中常用于替代电子继电器、保险丝和隔离器件。
    特性:
    • Dual 8.0 mOhm max high side switch with parallel input or SPI control
    • 6.0 V to 27 V operating voltage with standby currents < 5.0 µA
    • Output current monitoring with two SPI-selectable current ratios
    • SPI control of over-current limit, over-current fault blanking time, output OFF open load detection, output ON/OFF control, watchdog timeout, slew-rates, and fault status reporting
    • SPI status reporting of over-current, open and shorted loads, over-temperature, under-voltage and over-voltage shutdown, fail-safe pin status, and program status
    • Enhanced -16 V reverse polarity VPWR protection
    KIT33988CEVBE评估板用户指南.pdf
    766.52 KB, 下载次数: 0
    GMT+8, 2024-11-26 15:43 , Processed in 0.120536 second(s), 16 queries , MemCache On.
