TA的每日心情 | 开心 2013-9-2 09:06 |
签到天数: 11 天 连续签到: 1 天 [LV.3]偶尔看看II
CY8CKIT-035 PSoC® 电源管理扩展板工具包可供您评估系统电源管理的功能和性能。The Power Supervision Expansion Board Kit (EBK) supports:Rapid fault detection capabilities for high-availability systemsAccurate and reliable power rail sequencing of both power-on and power-off for four different power convertersVoltage and current monitoring of four different power convertersTrimming for closed-loop control of the power convertersMargining of power converters for developmental test purposesEEPROM based data logging capabilitiesI2C/SMbus/PMbus host interfaceCypress’s PSoC Power Supervision solution delivers all of these capabilities, supporting the largest number of power converters in a single chip. In addition, this solution provides you with flexibility to customize this solution for your specific application and the ability to further integrate disparate functionality like fan control, reset-control logic, I2C level translators, etc.
The PSoC Power Supervision Expansion Board Kit enables you to evaluate System Power Supervision functions and capabilities of the PSoC architecture. It is part of the PSoC development kit ecosystem and requires a host development board in order to use it. It is designed to work with the CY8CKIT-001 PSoC Development Kit (sold separately) or the CY8CKIT-030 PSoC 3 Development Kit (sold separately). You can evaluate the example projects described in this guide or design and customize your own System Power Supervision solution using components in Cypress's PSoC Creator™ software (included) or by altering example projects provided with this kit. | CY8CKIT-035 connected to the CY8CKIT-030 |
With the flexibility of the PSoC architecture, you can easily create your own custom Power Supervision solution on chip with the exact functionality you need, in the way you want it – no more, no less.Kit Contents:PSoC® Power Supervision Expansion BoardQuick Start GuidePower DC Adaptor 12V/2ASystem CD containing:User’s GuidePSoC Creator™ and pre-requisite softwarePSoC Programmer and pre-requisite softwareExample Projects: (for both CY8CKIT-001 and CY8CKIT-030)Advanced Sequencer and Power SupervisorApplication Notes and Key Component Datasheets |
