查看: 191|回复: 0
ispMACH 4256ZE接口板评估套件
  • 签到天数: 11 天
    发表于 2012-9-28 17:03:29 | 显示全部楼层 |阅读模式
    ispMACH 4256ZE接口板评估套件是一个完整的针对ispMACH 4256ZE CPLD开发平台。The board includes a prototyping area, a USB program/power port, an LED array, and header landings with electrical connections to most of the CPLDs programmable I/O, power and JTAG pins. The board is powered by the PC’s USB port or optionally with external power. You may create or modify CPLD program files using ispLEVER Classic software and reprogram the board using ispVM software.The ispMACH 4256ZE Breakout Board Evaluation Kit includes:• ispMACH 4000ZE Breakout Board – The board is a 3” x 3” form factor that features the following on-boardcomponents and circuits:–ispMACH 4256ZE CPLD (LC4256ZE-5TN144C)–USB mini-B connector for power and programming–Eight LEDs–4x15 prototype area–Four 2x20 expansion header landings for general I/O, JTAG, and external power–1x8 expansion header landing for JTAG–3.3V and 1.8V supply rails• Pre-loaded Demo – The kit includes a pre-loaded counter design that highlights use of the embedded ispMACH4000ZE oscillator and programmable I/Os configured for LED drive.• USB Connector Cable – The board is powered from the USB mini-B socket when connected to a host PC. TheUSB channel also provides a programming interface to the ispMACH 4256ZE JTAG port.
    下载连接:
    ispMACH 4256ZE 接口板评估套件用户指南
    ispMACH 4256ZE 接口板评估套件PCB文件.zip
    3.55 MB, 下载次数: 0
    GMT+8, 2024-11-26 15:50 , Processed in 0.117070 second(s), 16 queries , MemCache On.
