TA的每日心情 | 开心 2013-9-2 09:06 |
签到天数: 11 天 连续签到: 1 天 [LV.3]偶尔看看II
EZ-USB® FX3™ 开发套件给设计者针对加快系列中所有产品的固件和设备驱动程序的开发提供了一套完整的硬件和软件解决方案。The board can be powered either from a 5-V DC external power or from the USB host (VBUS line).Use the SW9 toggle switch on the board to select an option. If VBUS is used to power the board, populate J53 with jumpers. The voltage for FX3 I/O power domains can be selected using on-board selection jumpers. These domains include VIO1, VIO2, VIO3, VIO4, VIO5, REG_VBATT, and CVDDQ. All other power domains are tied to 1.2 V.A standard Micro B receptacle is used on the FX3 DVK board. VBUS power also comes from the host through this connector. The USB3.0 and USB2.0 lines go through an ESD protection device for additional ESD protection.The Cypress EZ-USB FX3 DVK includes the following:■ Development kit PCB■ USB3.0 A to Micro B cable■ Quick Start Guide■ Kit CD■ 5-V DC adapter |
