查看: 228|回复: 0
MachXO 2280 Breakout开发板
  • 签到天数: 11 天
    发表于 2012-9-28 11:02:05 | 显示全部楼层 |阅读模式
    MachXO Breakout开发板是一个简易的、低成本的,并提供便捷的间距密集的IO。Each I/O on the device is connected to 100-mil header holes. By adding test probes, jumper wires, or pin headers to the board, you can easily evaluate function and performace through the SysIO buffers of the MachXO2. This board is a 3x3 inch form factor, and features a USB mini-B connector for power and programming, an LED array, and prototype area. A USB cable is included with the kit, and demos area available for download.Key Board Features
    • LCMXO22800C-FTN256C device/pacakge
    • Pre-programmed Hardware Test Program (Source is downloadable)
    • LEDs
    • Expansion Header Landings
    • Prototyping Area
    • USB Mini-B Connector (Program/Power)
    • JTAG Header Landing
    • ROHS-compliant
    下载连接:
    MachXO Breakout 开发板用户指南
    GMT+8, 2024-11-26 16:35 , Processed in 0.125238 second(s), 15 queries , MemCache On.
