查看: 339|回复: 0
ECP3 评估套件
  • 签到天数: 11 天
    发表于 2012-9-28 10:38:58 | 显示全部楼层 |阅读模式
    LatticeECP3 Versa开发套件是工业行业中构建前缘系统的最低成本设计平台,被运用在在各种工业网络、 工业自动化、 计算机、 医疗设备、 国防和消费类电子产品等市场。 It brings high-end innovations -- configurable SERDES, cascadable DSP slices, and high-speed DDR3 memory within the reach of mainstream designers in an easy to use environment.The Versa Kit empowers designers to build both PCI Express and Gigabit Ethernet based systems. The Kit offers free design tools, readymade demos, reference designs, a versatile evaluation board, and a serial programming cable. The evaluation board features an LFE3-35EA-8FN484C FPGA device, 64 Mbit SPI Flash, 1Gbit DDR3 memory, expansion headers, several LEDs, and user switches. It contains a PCI Express x1 (Half-length form-factor), two RJ45, and 4 SMA interfaces.Development Kit Contents
    The LatticeECP3 Versa Evaluation Board features the following:
    • LatticeECP3 FPGA: LFE3-35EA-8FN484C
    • 64 Mbit SPI Flash Memory
    • 1 Gbit DDR3
    • PCI Express x1 Interface
    • 4 SMA Connectors for Electrical Testing of one full-duplex SERDES channel
    • Two RJ45 Interfaces to 10/100/1000 Ethernet to GMII
    • Expansion Connectors for prototyping
    • 14-segment alpha-numeric display
    • Switches, LEDs, and Displays for demo purposes
    • Push buttons for General Purpose I/O and Reset
    • Onboard reference clock sources
    • Programmed using a Mini USB cable via PC
    下载连接:
    LatticeECP3 Versa开发套件用户指南
    GMT+8, 2024-11-26 16:23 , Processed in 0.129200 second(s), 15 queries , MemCache On.
